Guest 87vlt
Originally posted by Boostzor
Yep sounds like u need to get a girl there Vspec. I met this great girl called Marie Jane she keeps you calm when your in the car and stops you from speeding too. Even  makes big brother watchable :bwhaha:
stops you from speeding or just causes you to drive at like 15kmh even though you think your doing like 110kmh .....
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh i was saying that prescriptions arent much better then illicit. They still work on the same principal and just casue u got them off a guy in white coat dont make them any better. Behaviour modifing drugs are more often then not used as a quick fix when really the solution is with the individual.
Sorry i like this subject alot:D
i know a few ppl on all sorts of prescription stuff and in most cases they take a turn for the worse.
Well i wont deny my driving needs improvement - mainly cos i live in la-la land but thats only because im going so slow i put myself to sleep. Once the foots down i reckon my drivings fine :D
Yeh big brother definately requires at least 4 pints before it get interesting. What was wrong with seinfeld? they could repeat the same ep over and over and id still watch it.
Just goes to show how many morons there are in the world huh
Yes i can also say that i think a lot of prescription is on the same level if not worse. Some people don thave a choice in their lifestyle - they just kind of get dragged into it - good on the ones that drag themselves out again :D
Oh yeah i run people off the road alright haha mmmmmm bullbar = instant power trip! But these were vehicles that were going to be sent up to the mines - i dont think they should be used for taking bob & jane to school every morning!!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
