  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
how do u tell someone tactfully to stop being a lazy bitch get off her fat arse and do it herself instead of use me as her shit kicker gopher when im a phucking level above her!!!!!!!!!!!!!!!! :D GRRRRRR
tell ya im pissed off - incase u couldnt tell. Thing is if i go her she'll just be a bitch - which she is anyway but thats beside the point! These guys talk as much as i whore so it does even itself out! I'll take it for so long then i'll get to wrath boiling point!
