  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
You stick with the coke but i dont know what you were feeding your passengers on Friday?
Ummm, you are talking about Vicki right? Well, she was drunk and has a loud mouth at the best of times. Thank god she passed out when she did!! She is ok though. Daniel, well, he was drunk too and was also feeling sick. Jeff, well, he too, was drunk. So, I was feding them alcohol. Were you the one Vicki was saying hi to out the window as we left the meeting point?
Yeah! She liked your car if you didn't hear her well enough!!! She loves Skylines to! She asked me who I thought was cute so she could set me up with them! I had to point to my b/f so I didn't get shot. Don't think it would go down to well!!
im not picking on u - well i not meaning too im just a bit grumpy today with stupid bitches thats all - didnt mean to seem like im taking it out on anyone. :D
And someone would have to have fangs like a vampire to get the sore where it is thru a bite haha dont know how it was done. its in the earloby bit.
Need more money 1st. Paying of the Corolla so just need to neaten it up and sell it now and then I will have one straight away! I can't wait. Just helped get a R31 cruise going and now have to listen to all stories of how good they are because I don't have a car to go in. If someone would like to donate one I would be most grateful!!! LOL!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
