  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I've changed my home loan from a std 25 year mortgage to a offset/equity loan. I bought the house 2.8years ago for $85,000 its now been valued by the bank at $110,000. I've got the loan down to $70,000 by paying a bit extra each fortnight for the lasy 2.8years, so I've taken a low offset/equity loan at $82,000. So I've got a bit of extra cash lying around incase I need it, but cos its an offset loan I should pay it off much quicker than the std 25 year loan. Its a bit confusing but I sat down and did the figures, going as I was the 25 year loan would be paid off in another 12 years with the new offset loan it'll be closer to 3-5 years depending on how frugal I am, quicker if my wife gets another job too :( Stupid education dept wont give her a job in the metro area :P So yeah, we want some french doors to open out onto our courtyard and I want to do more work on the car :)
Powerfc will set me back around $1700 delivered new with controller, then plus fitting and tuning. The autronics is $3500 drive in and out, but has boost control built in (if I want to sell the blitz sbc will make the install cheaper), traction control, serial port connection to a laptop with easy to use PC software so I can **** with maps when I know what I'm doing.
