  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by G0DF4Th3R
ah see thats whut im worried abt...i dun mind paying more for a dump pipe if its a better design...
what are the chances of getting a yellow if i have a screamer pipe like adrians?
hahahaa, they won't find shit :O unless they crawl under the car ;) hehehehe but then again i'll have my stocker on hand just incase :P which will be nusiance :P
paulie, you busy tommorow morning? i need sumone to bring me back from xspeed :( then i also need someone to take me back to xspeed in afternoon to pick me car up :(
adrian :P
bambam, the wastegate doesn't open till it hits boost :O so as long as i don't hit boost around cops they won't hear it ;) coz the wastegate will be shut :P dun worry ive worked it all out :P and it's definately not gonna produce any turbulence coz the wastegate gases going out to atmosphere :P just turbo gases going through the system i can't wait to hear it, and feel the diffrence everyone speaks of after they put a dump on :(
adrian :(
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
