  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
not really but he did a little 'sing along' to the radio on the way home.
Was it Naomis choice of song? Would have been Led Zeppelin. God that woman has got good taste ( except in Husbands ) Hehehehe
Cheers
Ken
Originally posted by Nizmo
good evening all? :D
Evening Niz and thanks for the party invite. Had a good time and cos I was sober when I got home there was no problem.
I see that Mel didn't improve as the night went on. I bet she drove the porcelain bus a few times. Hehehe
Cheers
Ken
yeah she drove it in the morning - haha geez she makes even me look sober :D oh well its better her be drunk otherwise shes really normally quiet.
No probs for the invite - thanks for your company :)
Happy birthday Troy
Hello Kyles
i had controll of the radio ken :D hehe.. Nothing on at that time of night
Hi niz,
Troy get your birthday arse on mirc :)
Nite Cam.
You 2 off for some private internet sex and flirting.
Why don't you stay here like before?
Cheers
Ken:D
Hmmm , then Mel must have been well on the way when I got there cos she wasn't quiet then and that was only 8.30 .
Would have been fun to stay and stir her up but alas, the trouble and strife beckoned.:D
Cheers
Ken
Internet bonking, na he can hold out untill the weekend :D hehe.
We are going to see "he died with a falafel in his hand" on friday night :)
A WHAT in his hand ??
Cheers
Ken
yeah well what happened is she got there at 7pm with chantelle i just got out of the shower at that time cos i had a nanna nap before and i then realised there was cooking etc to be done so i was running around like a chook with its head cut off and my friends decided to instead of helping on my birthday they would watch me and start drinking. So i didnt start drinking til just before ken got there :D
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
