  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mmmm i like laptops - i usually borrow the work one and set it up on my desk just for the novelty of it - im usually very bored here - have heaps to do today tho - in denial about the work haha putting it off.
