  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nah my job aint important just another govt worker that doesnt know why the phuck they are here haha apart for money :)
Ricey question - how do i get neon to light up skyline sign like Alex's hehe :) actually that is serious - looks good.
niz,
1. buy heatgun.
2. remove panel.
3. apply patience
4. apply heat
5. apply prying force.
6. repeat steps 3 through 5 as necessary. note step 3.
7. buy blue trailer light from marlows
8. wire up blue trailer light only to discover that it looks shithouse
9. buy cfl globe and cff board from jaycar
10. break globe in half trying to thread wires
11. somehow dream that you can stickytape a flouro light globe back together using pvc tape
12. wire up board without thinking
13. fire up board and sticktaped globe
14. swear when the capacitor in the board explodes in your face and temporarily blinds you and burns your arm
15. go back to jaycar
16. this time, be very gentle with the brittle globe and wire up correctly, taking into account the prescence of red and black wires on the board.
17. wire switch inline.
18. discover switch is wired the wrong way around.
19. curse and tell yourself that you dont give a shit.
20. put it all back together.
note: items 7 through 15 are optional. :)
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
