i dont like maccas - it just sits in ya stomach - apparently if u eat maccas and they cut u open a year later the forsenics can still tell u had maccas back then cos of all the preservatives haha
Like a whopper - but i take the meat out usually to stop that sitting in my stomach as well - hate the bloated feeling!!
I just had a really small piece of chicken parmigiana and steamed veges for lunch :)
I need to learn how to control my car in the wet anyway - i have a phobia about driving in the wet i need to overcome - too many close calls in wet in the ZX and most of my driving lessons were done in the wet and they werent happy memories!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Women's Advice to Men
The reason why our bras don't always match our underwear is
because WE actually change our underwear.
The next time you and your buddies joke about armed women in
combat, take a poll to see which of you successfully aim at
the toilet rim.
If we're watching football with you--it's not bonding--it's the
butts.
If the truth hurts, ask us those ego-sensitive questions on your
payday.
The next time you joke about female drivers, research the number of accidents caused by rubber-necking mini-skirts.
If only women gossip, how do you and your friends keep track of "who's easy"?
Stop telling us most male strippers are gay: we don't care.
Your contributions to your child should go above and beyond that y chromosome you unselfishly sacrificed.
Your balding is a good thing--it subsidizes our hair care expenses.
    • Talk to hot girls via live cam. Adult dating made easy and exciting. https://secrelocal.com private ladies for discreet encounters
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
