  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah chaos he was usually telling me to get my butt upstairs i had work to do haha. Yeah but it was a bit crazy 26!! i did ask him why just said he liked the variety - i think he had a secret addiction to the stuff
Hey Campbell - sorry for some reason i thought u were cam as in cameron til i read your CV and thought shit haha ive been making an idiot of myself. Thanks for that Cam much appreciated :D
sorry u shouldve corrected me - must admit Campbell is an unusual name tho.
Yes it did thank you - i had the format of my CV already sorted just updated it. But they had about 10 points of criteria you had to address in a two pages or less kind a essay - thats what i was having trouble with - but yes there were a few ideas you gave me!
Haha i just got bottles of perfume - just finished one given for my 18th bday - lasted me exactly 2 years!! I hate buying perfume tho - always better when someone else buys it for u!
i must admit certain deodrant smells to get us girls attention - specially if someone special to us used to wear that deodrant.
must be pretty friggin strong deodrant Ben - works across countries haha :D
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
