  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ken - impressive list.. :D
aidwin - i don't think i'm the person to be teaching anyone anything to do with driving! tho after the understeering and conering lessons with ken i feel i have improved quite a bit.. much more comfortable when things step out anyhow...
night Liz
haha i found it hard saturday when u have your normal patterns of driving and ken is telling u to do one thing but your brain is telling u to do another cos its just what u normally do :D
Originally posted by SHUTO-BOY
wow drift series- id go watch it,its a nice sport to watch
Watch , dammit man , ya gotta have a go.
Put the crap tyres on the rear and a mechanical type LSD , bit of negative camber in the front and your there.
Cheers
Ken
PS Nite Liz , I think theres an all female day at MC on July 12th.
Originally posted by Nizmo
night Liz
Yuor normal pattern. That gearstick / shifter certainly gets some attention...
hehe
Cheers
Ken
hehe oh well gotta have at least one knob i can play with :D
just when started at new town i got used to driving prados and other manual cars so now even if auto resting my hand on the shifter is just what i do :)
mechanical lsd<-- so its easier to correct the car after you go sideways?
Nope but it's easier to get it sideways.
I got a 1.5 way cusco locker thingy in the back of Ricer and that goes sideways REAL easy. Ask micko , Cam or Niz.
Cheers
Ken
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
