  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I just can't see a manufacturer saying .... Ok lets install some blanking plates through our cars in case the people that would like to purchase them want top install aftermarket switches....
Hmmmm your probably right but the switch just looks so factory its not funny.
never stopped us talking about it before haha
yeah i got blanking plates in my car - but ive been in other skylines and where i have blanking plates they have things - where i have buttons they have a blank spot - all they do is produce the base model then install the switches according to whether its Vspec, Manual, Auto etc :) So where u have a blank spot - on another model it aint blank :D
i'll do the washing but stuff the ironing :D ex always had a bit of trouble getting me up at 7am in the morning to iron his shirt - always greeted back with a "f off if u were dumb enough not to ask me last night it aint going to happen this morning" haha
Originally posted by GTS-t VSPEC
Troy, I was impressed to see you working on Micko's car the other day, never seen you get your hands dirty before:p
pulling pipes off and afm's etc i've done b4 so seeing micko was sort of grieving even though he had this big grin on his face, and the fact i'd have to leave early i did my bit :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
