  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
and he's 25 not a year younger than me like Scotts mate hmmmm i could imagine when im old and married my grand children going to me "so nanna how did u meet grandpa?" "i dont know sonny i was too shitfaced to remember"
bring him to albany we'll turn him to the skyline side
Originally posted by skyzerr33
niz what intrigues me is that u went and had drinks with him after not remembering who he was or where u met him
Troy but i thought i knew who he was - i thought he was Scott (who has been a very good friend to me) i thought it was his mate - in fact i was certain it was his mate cos thats the only guy i thought could possibly have my number at the end of the night. Scott hates my ex andrew and ever since he got his way and Andrew and I broke up he doesnt trust my judgement in guys - so Scott often takes it upon himself to try n set me up with his mates. So i was more than safe having a drink with one of Scotts mates.
But Billy has nothing to do with Scott - Fked if i know where on Sat night i met him but i cant say im complaining the boy is like too good to be true and just appeared outta nowhere!! :D :D :) Im currently sent an email to my mate Mel to see if she can piece together the night a bit more for me.
hey Cam - haha there should be more randoms like him i tell ya :drooling: nah i just cant believe i cant remember it - people like him u remember. Maybe u should try it Cam :D
Anyway otherwise im good - apart from the wheels on my car - they are starting to thud over the smallest bumps now - not bounce - i say i might have to give up Pauls EBC and go the wheels and buy an EBC later down the track :D
Niz - I didn't read back but I'm guessing he wasn't bad... as for trying it - I'm always out and about drunk - for some reason none of the girls are ever as drunk as me.. :bonk:
Why do you need the ebc? You already have a bleed valve right? I'd say tyres would be higher on the list wouldn't they? Thye kinda make your car move a bit easier.. :D
mechanics of the car is fine - the wheels at the moment are dodgy - i hope it has nothing do with suspension and just the wheels getting worse.
I have eggs in my tyres Bam which means its liek driving with square tyres - it hasnt got worse for a while but last night driving home from work - its picking up every little bump and its going thud instead of bounce - im going to check tyre pressures as well - tyres look lower than what they should be but nowhere near anything that should cause a prob.
Just eager to put new wheels on Bam - so my car can handle normally again!!
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
