  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
G0DF4Th3R, not quoting 2f2f i hope. No spoilers, I haven't seen it yet!
Watch the first fnf last night on dvd. To quote Boostzor: "Man, I feel like nailing my balls to the table just to distract me from the pain of watching watching a movie as shit as this". :P
Hmm, well I could burn the rest (2 discs) if you want to come by my place and pick them up. Or meet up at Curtin this week?
Can you look out for the movie Shuto no-something on pirated vcd or dvd in Malaysia? Shuto-boy was on about it and I'd like to see it. :P
