  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha im sure they could incur my wrath and i would fit in well :) except ive got to learn to complain about my boobs :)
haha its got a walk thru of this matrix thing - some people take movies way to seriously there was a guy interviewed who was a scientist who thinks the matrix exists - hmm what about research into cancer or something useful people!!
