nah biggest thing ive ever "borrowed" was a candlelabra from Burswood :) u gotta have momentos! :)
Dyno day hmmm i want my sticker so i might make an appearance n grab it and then go croozing with Liz - they are talking about the club then arent they? oh well i dun care i f i miss out on that - to me a club makes things more political - i have enough politics at work!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
niz - u can pay at east perth, but if it's past the date on the final demand notice u gotta do it at the court.. me done it a few times now to buy extra time.. :)
me off for some lunch.. got no work on so might make it a long one.. :)
back to whore yas later..
a big hoity toity candle stand Bam :(
someone remind me in half an hour to do my time sheet :)
oh well paul - i think your current driving is boring too - so we ar equal :) i almost said to u last night "for god sakes pull over and let me have her" haha but thanks for your advice n explanations - im happy now to know it was just me being a fussy bitch :(
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
