  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fwd is no fun ever. I can put my foot on the brake, other foot fully on the accelerator, and go nowhere, just revving. When brake is released, car still goes nowhere for another 5 secs. Hmm, disappointing, much more fun in the Commodore. Blame my Dad for that comment! He took my damned Skyline. I shall never be over it.
Gotta go anyway, have work to do,
cheerio!
Originally posted by Nizmo
Bam - DO NOT TOUCH HICAS!!
u need a special lock kit to disable it - u go pulling plugs out willy nilly and ur car will be unable to drive - go ask strich9 he did it. SPECIAL LOCK KIT NEEDED!!
That is correct.
Thanks for pointing that out Niz, I almost forgot, well, tried to anyway....I pulled out the HICAS computer located in the boot under the parcel shelf. It disabled power steering completely, and was a BITCH to drive.. hehehe. Don't try it.
I _DIDN'T_ However, try to pull out the three little plugs on the HICAS actuators under the car (near the diff) to disable it. Hmm.. That get's me thinkin....
*It's time to watch Kym do something stupid and be the guinea pig again!!*
off i trot....
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
