  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Niz I couldnt care less about the people i work with atm. Exp my boss... Not one phone call or anything while i have been away to see if im ok.. nice one. Gez when tana the cook had her wisdom teeth out a few weeks ago my boss went to her house everday and called her everyday to see if she was ok, and everyone chiped in for flowers.. I know im loved lol. Bloody rude i think! I think my operation was a tad more serious that bloddy wisdom teeth..
Kyles yeah i know - my mum used to get pissed off at Newtown cos when she used to ring to say i was sick (and i was really sick back then) they acted liek they didnt get a phuck just wanted to know when i would be back at work ...... because i was the only one that knew how to do anything around there!
So u looking for jobs like me at the moment ..... not much out there!
im just going to put up with it for another 6 months then off to uni and they can get ****ed! I wont even do relief work for them.
And they can get stuffed for extra hours making stuff for them, not going to bother anymore doing that stuff.. if they dont make the effort for me, i wont for them.
lol niz. thats so true.. Yes i more suit the cow right now lol... hell i have trouble walking down to the shops atm. I went to get some bread and milk this morning, and it took forever cos i had to walk slow and take it easy.. sore when i got back :)
I was thinking of going back to work today for a few hours.. I dont think so.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
