Originally posted by Micko
How many k's tonight ken?
Getting the ecu tuned tomorrow?
Let us know the outcome eh?
Nope , run in and been at Lumpy's getting the chip re rit for a 7500 rpm revlimit and plenty fuel
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
checkin up on your dafaming ass!!!
hey ken, rob, micko.
hey ken,
how often do good deals on 2nd hand racing seats come up on your auction site?
Plenty on the jap auction but shipping is the killer.
Paul , am doing the Full Monte rally which is like the classic rally but 1/2 the price.
Cheers
Ken
Originally posted by GTS-t VSPEC
Alex, It's only defaming if it's not true:p
Phil, I ain't scared:D
Ken, How many K's till you can let her rip?
Already have , 1000km and I clocked that up last night after 3 nights cruising ( !! ) the freeway.
It's 69 km from roundabout at Baldivis to Hodges dve.
Cheers
Ken
Ken - no autronic yet?
Nope cos there's not time to tune it.
Paul the 7500km was put in tomight after I run it in at less than 7K .
Long process involving lots of part boost , 3 , 4 then 6 k rev limit and other crap.
Feels strong so may have been all worth it.
Cheers
Ken
Ken, Sounds good, wish I was there to film it:( Good luck with it though, is the Mrs navigating?
Nope this is a seriuos navigation event and I would prolly abuse her.
Got some dude who had the 1/2 entry fee.
Cheers
Ken
Ken, It had better be worth it after all of that:D What does the engine bay look like? Nice and ricey?
Yea , pretty blue cover and polished intake and terb pipes.
hpc type coating on terb exhaust housings and manifolds.Works well , bugger all radiated heat.
Cheers
Ken
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
