  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by XRW
hey im not driving, im not licenced to drive a truck :P
and we'll be going slow enough so i can get a good aim as seans truck doesn't do much more than 100 :D
Huh ?? yo going over with feral ?
I wass asked to drove the truck to Mel for next w/end but I don't fancy driving a unknown semi cross Oz 1 up.
Cheers
Ken
Cheers
Ken
yah probally, i think the car is going to winton this week in nials truck? or something like that, and then hes using his transporter to take it over to oran park after the next round at wanners, well leaving on the monday to go over..
Originally posted by GTS-t VSPEC
Ken, Could always ask her:p
Denver, Do long trips put you to sleep?
Nope, i can't sleep in anything moving, unless im pissed as or completely exhuasted..
the only exception to the moving rule was the fairstar, but that was a floating city in boat terms..
a deep and meaningful with the GF will knock me out quicker than mike tyson could tho.. :P
Denver, Why you working with Sean?
Keen to see what 3j is like over east, as theres lots of push for it over here to be brought in as a main class, so i wanna scope out what its like over there..
that and im keen to see sean do well over there, so im all for helping out where i can..
Last I heard was he was going in Clint Harveys pantech but no word of taking his own truck ?
Cheers
Ken
Pissed is easy. Just take a few cartons for the trip, you'll sleep like a baby:D
just do a round of ths speed series where you egt up at 4am to drive to collie, spend all day outside competing and walking around then drive home, i usually have to get the passenger to drive after i get through harvey or ill crash because i need a kip..
Cheers
Ken
for oran park, or winton?..
its on harveys tomorrow to go to winton, then comes back, does the next round here at the end of aug, and then goes to oran park in his truck..
Ahhhh , I see..
Who is driving the truck to Oran Park ??
Cheers
Ken
i belive im putting my life in the hands of neil, as he told me today, knowing sean the plan will change again next week, but see what happens
Neil , thats the other big guy in the Feral bedshed shirt who was pitcrew ?
Cheers
Ken
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
