  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha how was those Silvia dudes on the way back haha i pulled up beside them at the lights .... and i go "Learn to drive guys" :D and then took off haha they spen tthe rest of the time trying to catch up to me then beeped me as they turned off. Sorry about squeezing in between you n that 4wd drive .... i came pretty close to your rear end - but i didnt have to slam on the brakes or anything it was all fairly under control ..... it scared the shit outta Mel tho :D
yeah cos on mitchell freeway had to turn off to Leach hwy and they were being dicks and slowed right down ..... so i was right up their are swerving back n forth across the road then though phuck this shot past them and back in front of them .... and thats when we got to the lights to turn onto leach i told them to learn how to phucking drive haha their mouths just fell open and didnt know what to say then they went "hey" and lights changed and i booted it.
oh after you guys turned off i pulled up on leach and guy beside me in 4wd pulls up and shouts out the window to me "So did ya win?"
Cant understand why you didnt pull a "Peelie" for the RAC guy Liz mightve given you a free lube as well as your jumpstart :D
Yeah you n I pulled a few Ch33ky stunts today but its all good 'no cars were harmed in the making of this cruise' :D Knew Mitchell freeway was going to be fun.
haha nah we went to the Rivervale ..... our bottle of wine arrived before the food and i hadnt had any breakfast etc so it went straight to my head it was pretty funny ..... food there is yummy tho :D wouldve invited you but i thought you may of wanted to get your car home!
Originally posted by Sneeza
the difference between us pulling "cheeky's" and cheeky driving like a *****tard - is that we really do have skylines..
:lol:
Plus by the time you cut someone off and step on it your far far away before they have a chance to go up ya arse :D my theory anyway ..... it was a pretty risky move me shoving myself between that 4wd and you but i didnt realise the lights had turned red ..... and i started apolgising to this guy in the 4wd that asked me if i won thinking ti was him i cut off ...... but he just looked at me weird.
Hey Ken ..... yes had fun :D we always find some unsuspecting piece of shit to play cat n mouse with :D
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
