  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dan - provided that they do not impede your vision they are ok.
Although it's best to have an inline switch for the lights, so that if you get pulled over you can flick them off.
I think there is an ADRule about having illuminated gauges above the top of the steering wheel or something. Though I don't know how that works for heads-up displays..... :shrug:
Im going :D
Dan - just go through taka or better still - greenline.co.jp
Most of the local people have had the shits with stockingperformace gear since everyone just gets it direct anyway.
get the trust pillarmount from greenline too. they're heaps cheap!!!
You'll find no-one will have them in stock and it will take you longer to get it in via them than through japan direct anyways.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
