  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yes Obviously my new avatar wasnt a big hit with the crowds :D
So you don't have avatar's turned on Niz??? Does that mean your Stagea question wasnt in relation to my avatar then??? I assume then you were just rubbing it in from last time we spoke :)
Dan ..... my mum said yesterday she gave you a wave :D haha i told her to blow you a kiss not wave :)
Richie - probably not a good idea to do it on a "bluey" cruise! ... i actually had a panel beater geniunely lose my front plate once .... i picked my car up and the guy had already shut shop and i go to dad "where the hell is my front plate?" i drove around with it half naked for about a week til i got it back.
Im thinking of getting a brand new GTR spoiler .... the one on back of my car is pretty much phucked and irrepairable i think.
no for work reasons i have as much tunred off as possible .... still looks like im phucking around on the net tho but i dont care - two weeks left :)
Yeah the comment was from last time we spoke.
haha *niz gets popcorn* i just love a good lovers tiff .... keep it up boys :D
haha becareful Dan ... she has your number plate memorised .... she goes to me "Do you know a red skyline with number plate *insert here*" and i was like what tha? yes i just know the number plates of every skyline on SAU off by heart :)
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
