  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bam - exhaust/muffler places or places like Xspeed or works?
To get a secondhand N1 from somewhere would be the cheapest. Anyone in perth retail second hand imported Jap stuff??
even marlows sell N1 mufflers now - I think theyve got some australian made carbon fibre mufflers - which are pretty cool apparently - my mate with the 180 was going to get one last I spoke to him...
Yeah I havent regreated buying the HKS kit at all.... very pleased with it.
I go a pleasant surprise yesterday.... I got a phone call from my boss stating that I havent been getting my on call money for the last 6 months...... So I have to make a claim for 6 months of on call.... which works out to be about 24 weeks x a little over $300 a week ... granted it will get taxed a bit but say good bye to all my debts and I will still have some left over..... Probably explains my good mood :D
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
