  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I can't help it if a have the gift for playing cricket and the centre needs me to help them win :D
Hows the for blowing my own trumpet....
But really if the cruise leaves early enough I may be able to come along and just leave early in the afternoon....
considering it ....... do i really want to part with the cash just yet is the question....... will seeing my bank account afterwards just make me more depressed ..... probably ..... lots to ponder.
Mum made a really yummy dinner last night .... pity i couldnt eat it :D one night she makes yummy dinner i cant eat it.
doing my own washing tonight ..... did soem last night .... was onto my last pair of undies.
Yeah Alex I already have full exhaust.... but if you change to a monster sized turbo I would have to change it then....
Paul... Looking at my dyno chart from SST, the chip does very well at mapping my air/fuel mixtures.... The only thing changing to full management will be able to sort out is my lean patch in the middle I would say...
