sorry looking at other threads - but im done now :)
im having major gym fest on my days off cos i have been lazy lately!! Plus i wont eat as much when im at home.
Sweet so you coming on Sunday?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Meet at City West at 10 - 10:30 (check events thread not sure) .... maps handed out on the day but we are ending up in john forest nat park for BBQ lunch BYO meat n beer.
depends how i feel after saturday night whether i go or not .... but i went to dardenup cruise and i was trashed .... although i had somebody to drive otherwise i might not of survived haha.
ahh good weather on sunday is a good thing....
i am getting pissed off with my car, if i accelerate hard up to (and mybe over) 120 i can hear a whining noise coming from the rear of my car, i hope that its nothing. i got a feeling it might be the wheel bearings tho...
might treat myself to a couple of pints at little creatures on saturady i think..
not my idea :) Mel's housemates who i dare not argue with cos they get in a huffy...... they wanted to go Metros RnB Superclub first off and i put my foot down about that .... we only went there a couple of weekends ago. Must admit theres good eye candy in Freo tho :)
eeek not good :) ..... my cars such a slug at the moment .... feel lime im driving a commonwhore gonna leave it til i save up a couple of grand then go see Jash and see what miracles he can perform on it. But i must admit its gone thru going thru about 2 -3 tanks ( 3 on a cruise week) of fuel a week .... to one tank of fuel on a cruise week!! Why all of sudden is the fuel economy got good???
DC's? Drum Club??
yeah last time i was there was my 19th Bday but i was too sick to care trying to control a crazy off his face boyfriend ..... so my memories of the place arent that good.
um fuel economy got better not worse.
haha yeah havent been in ages .... check it out again one day.... just have bad memories of the place that'll stick i think. Bit like the Rise dont like going in there too often these days as well.
Y compo?
umm, i did that about 2 years ago now, i only got my arse into gear to get the compo cause i am getting out... and yeah it hurt like hell... got some nice morphine at the hospital though!
i dunno how much i iwll get but i have been told about $5000, that should be nice but i think that my car will miss out, just cause i have got the shits with it and by the time that i will get it the house will need painting and the gardens will need doing...
Such a nice feeling when your boss has gone to Canberra for half ya last week and you know when he comes back you wont be there to be shouted at if things havent been done ...... ahhhh freedom. :)
My cars interior is in desperate need of a clean - i used to keep it spotless but at the moment its really untidy!
$5,000 & Morphine wow .... *niz looks around for airtight doors* ...... Doh! :)
haha i bet you spend it on ya car anyway :)
Guys with cars n houses never spend any money on their house unless its neccessary!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
