  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i lied to get out of going to a friends bday party - which i was given late notice too and he hasnt bothered to contact me in ages anyway ....... but still he came to mine and we were once really good mates (not that good he's a bit on the feminate side if u know what i mean) but do you think im a bad person? i feel really bad about it!
Originally posted by rb25
oh - sorry mate - im workin and whorin at the same time so.....
well - i live about 30mis from work and shes about 1.5hours. too far for her to drive - boo f**king hoo. she only stays one nite a week and it will stop in 2 weeks when hubby is home.
but why YOUR house?? is it work digs or something??
or did you volunteer? its a bit freaky is all!! do you get any thing out of it - apart from freaked out?
not usually - usually im pretty honest. But this week - yeah cos ive been getting in way late and leaving way early for 'brake stuff' and taking an hour for lunch ...... ive lied big time! but firstly .... no matter how late i get in - im still in before my supervisor. 2. he's constantly out to meetings so he has no idea how long i take for lunch and only he sees it and signs it so theres nobody else sees it to dob on me :P
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
