  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lauren - its through a firm that arranges the teachers for the uni's and stuff in Singas. The head of IT at murdoch set it up for me. I want to use it more as a means to get my name known - I'm not too fussed about work, the unemployment rate is very high in singas at the mo and they are trying to cut down on giving jobs to overseas ppl.
apparently been busted for a little while they said by looking at them .... i went there for a brake pad change and a machine cos they were vibrating so badly!! .... actually so badly they had to get them machined off premises cos theirs wasnt heavy duty enough to handle job haha
bwahahahahah
nice work..
i gotta get my bum in gear and start putting my bunky back together which means putting the big big brakes on again, im tempted to just wait till a decent gearbox option is affordable, and putting some 6 pots on the front and the alcons on the rear, ahh money its so nice to have it.. and then spend it..
haha Denver .... what you doing to that poor car ... why i wont come play motorsport with ya .... turns ya cars into bunkies!! :)
it had the lot Liz: Sex, Dicks and size, midgets, orgies haha you wouldve been impressed :D
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
