  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i know Paul so sorry only got it this morning cos my battery died last night - so it spent all night on the charger ;) .... you know my phone - the battery in it only lasts two days max!!
