  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
OH MY GOD EVERYONE ...... MONDAY I START WORK AGAIN ..... AT THE DEPARTMENT OF INDUSTRY AND RESOURCES ..... AGAIN ..... BUT FOR A DIFFERENT GROUP ..... THE BOSS REQUESTED I SEE HIM ABOUT 15 MINS AGO AND TOLD ME THE NEWS!!!
for once .... with a job do i not land on my feet?????! jobs are one thing i seem to have good luck in!
oh and a chick at the good bye read my palm .... apparently shes NEVER seen a palm like mine!! Im going to have a LOT of indecision in my life and a lot of relationships :)
alex I HERE YA .... about to have another piss up myself - and man i can hardly drive home as it is!!
well Ross i told the IT guy and he went - Phuck them Phuck them all ...... so i guess i'll give an Amen to him :)
Hey there everyone.
I'm in need of help from mechanic types. Is it possible to remove injectors while the fuel rail is still on the car? I've been trying for a while and they don't seem to want to budge. Anyone removed injectors on a RB25DET beofre? Help!
I'm replacing the upper plenum so I have full access to the rail and injectors. The cap on the injector unscews easily enough, and I can get the injector to rotate in the rail, but the injectors are impossible to pull out of the rail.
I think I'll pull the rail out and work on it on a bench.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
