  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i made these pasties and in them had ...chicken, bacon, spinich, brie & tasty Cheese, packet of crema of chicken soup mix ..... its kinda an old receipe of my mums but i think i can make it better i think just cos i put more stuff in it :D
yeah i need ot get back to gym - been rather lazy lately.
today is a wonderful day - hope its liek this on the weekend!! im so hanging for summer hate this cold crap weather .... and the car stays cleaner for longer in summer too :D
i quite enjoy cooking for myself cos if it turns out crap then i only have to eat it :D haha
It was easy cooking when i was living outta home - cos when your living with a diabetic - the choices on the menu can halve haha
complicated?! agh buy the ingrediants i'll show ya ....
you should cook for Alex and his family one day considering how much they do for you ........ actually quite a lot of people you are indebted too!!
cool :D
cant understand why Ben couldnt handle the problems in the business for phucks sake he's director of the new one he should be big enough and ugly enough to handle things - instead of getting my dad to run back and babysit him!! :D
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
