  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
next saturday aidwin - pauls considering it .... he has his dads birthday i think earlier on but it probably wont kick off til 10 - 10:30 so he thinks he can make it :D
me n liz got a room at burswood
