haha .... sub ive got it on "safe" view (no avatars) for work purposes :) ... its in events .... going out to Casino on Saturday 6th (next sat)
Hey James long time no whore :) where u been?!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha well that shouldnt be a problem then Allan :)
Funny thing is i used to go clubbing when i was 16 with not much probs .... but i was modelling etc back then and looked older. These days they ask for my ID then look at it funny and give me 20 questions cos i look all proffessional in my Drivers License photo and when i go clubbing i look funky and different.
Single aint a bad life James :)
