  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey Brett :( how was the weekend?
Paul that was my point exactly - the other skylines didnt have your diff and they still found it hard to drift ...... face it .... we are meant for the drags n track ..... not drifting
come to think of it i havent actual seen any decent footage of an R33 drifting ...... from anywhere. R32 - definately .... R34 - yes (but i have a sneaking suspion it wouldnt be cheap set-up) ..... but no R33 and ken has done more spectacular work in other vehicles ....... im beginning to think that R33's aint the best vehicle to have if you want to competively drift .... my 2 cents :(
yeah sunshine was awes - my first sunburn of the season - im so proud :)
I think my terminal speeds were around 105/106 as well.... I dunno... I just couldnt seem to put it all together... There was one run though were I seemed to get the launch perfectly but when I slammed 2nd the jolt loosened my AVC-R which is attatched to ash tray, which promptly felll back onto the gear stick thus I couldnt put it into third until I put it back in the socket.... so my possible great time turned into a mid 14 :(
Hehe I got sooooo sunburnt at the motorvation last summer that I still have the tan... I think it could have been classified and 3rd degree burns :)
Originally posted by ReVN211
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :)
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Maaate... you need to have a look at mine, I've got a 'good base' car for you. With your choice of Nitrous or non-nitrous config.:(
LOL @ Brett ..... i used to go so brown when i was about 7 (cos we spent all summer at the beach) that someone asked my mum what nationality i was one day :(
I have a photo and my legs look like a Aboriginals
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
