nah i was on the freeway going north (on the on ramp near the city) and it was an 80 zone (however i thought was 100) and because no one was in front of me, i gave it a bit of stick. Because i didnt see them (they were well behind me), i just kept going faster. They had to acclerate to WELL over the speed limit to catch me (i wasnt running and they knew that).
They were nice guys and said i was at license loosing speeds blah blah blah. Which i was (so no point getting upset at them)
They reduced the speed down a bit so i wouldnt loose my license etc.
THEN they said theres a time and place for everything and havent i heard of ISD's WTF!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh that was the odd thing. I just played dumb and said i've never heard of them or never been.
I mean the freeway, with little traffic is one of the safer area's to speed. I could have been booting it down a suburban street with kids playing (which i dont)
Ohh well shit happens.
Shuto boy. my mates wrx is phucked. He got a quote to fix it using a JUN stroker kit and MOTEC. 19K all up!!!!!!!
Yeh but paul my insurance will be so high once i loose my license
yeh, ummmm, err GF doesnt know and whatever i spend on my car i just halve :D she would have my balls if she knew how much all this will cost
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
