  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cool :D me playing Erica cheekyR32) is SA was funny - both her n i couldnt play for shit so by the end we were just moving the balls around the table to suit us in 'special girls rules' :D
one house that me n mum love - it has an atrium up the middle of it marble flooring etc etc but dad sees a bit more work still to be done is just across from Morley High.
But mostly looking St Andrews/ Dianella Heights/ Dianella
cool - we'll be neighbours.. :D
me still trying to find something temporary between movin from this apartment and when my new place is finished. may have found something in claremont but not sure yet.. am taking a drive out there tomorrow to check it out...
Claremont is nice :D so you building then?
u going to put a big mo-fo jesus statue out the front of ur house Cam? ..... in keepng with the suburb n all.... have u seen some of the dirty big jeebus statues some of them have adorning their gardens?
yea - will see what the place is like tho..
I bought a place that will be finished in December.. a guy is building two duplexes. i'm getting the front one and he's going to live in the back one...
statues? lol.. nah.. not my style... :D
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
