  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
vspec, you know when the track (plex) is being prep'd this season? i think i'll take up rev210's challenge:
Let's see a front mount intercooler equiped R33 gtst with a stock turbo run better than a 13.3 @106mph on 205's. To the best of my knowledge there isn't one.
