  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL coming to check the Alkaline levels eh Adrian :(
haha trust me Adrian .... u dont want in on wednesday! ;) but guys are going to fast eddies on thursday .... that would be a little more "safe" i think :rolleyes:
nah - theyve got their own cd that they use - it's got a whole lot of frequency sweeps...
DNB would win tho....but it would empower and enlighten the judges and then they would start to weep, for they would realise that all they have known was without honour and lacking in purpose.
they would see the light, just as you will......
why is everyone getting married lately ..... ive received so many wedding invitations this past year .... 4 friends i grew up with .... 2 got married this year ones a year older the others a year and a half younger ........ weird.
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
