  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no never neons!! or a GT wing!!
Its going to be a secret ...... if i get this new job with car ..... then mine will just disappear for three months and come back looking quite quite different...... yes but i will own up to the fact checkerboard plating will be going into my car :rolleyes:
i think its time to "personalise" a little bit before it becomes a clone of every other black R33 out there :rolleyes:
But it takes quite a bit of cash .... so depends on job situation whether it becomes possible or not.
Wide body kit is a bit out of the budget .... as is a full respray .... which i would consider if i had the money but $10K on just making your car a different colour i dont think is worth it.
yeah i would love to respray a blue .... :rolleyes: when i win lotto maybe
well as you know rear wing is in desperate need of replacing ..... but no reason to go the whole new kit ..... 400R wouldnt fit on my car anyway without scraping on the ground
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
