  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah nothings bounced back to me and im sure the addys right :(
I dont think the Laser could be capable of speeding .... i think my license is fairly safe in it. It fustrates me sooo tho .... i dont realise how much anger i take out on the roads til i cant take it out on the roads anymore :D
yeah im off in 15 myself .... have a good one Lee!!
you can still make the Sssssh noise Cam ..... :D .... i do .... i got no radio so i gotta have some kinda fun.
There was a traffic jam this mornig cos there was an accident not far where i had mine .... anyway you dont realise how easier autos are in that situation til you have to drive manual in it ..... 1st just into second then you have stop ... 30secs .... back into first ...... crawl 10 meters .... stop ...... take off again for another 10 metres .... stop ...... phuck the gym .... my legs are getting enough workout on that clutch!!
yeah Cam i can imagine .... hence why for my purposes .... an auto is perfect!
i dont think that poor Laser has ever been revved so hard LOL ... when i first got it i was coming home from work and i took off but cos im used to an auto i forgot to change gears for a little while :D
Anyway im off home .... see you at 4:30 paul
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
