  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have to be ...... put on so much weight over the holidays .... too much fine wine n junk food! And Auto Salon is looming rather quick and im paranoid about looking frumpy for it. So yeah this last week ive been doing rather full on 1 1/2 hour sess's at gym and been watching what i eat .... kicked the alcohol (and my skin is looking tonnes better for it) .... just behaving :) cos normally im the biggest junk food eater, laziest person and can consume alcohol like the best of the blokes :P
yes well unfortunately ive got the child bearing hips that just wont go away *mutters underbreath stoopid DNA*
oooooh sounds like its all go for you Phil :P
Should hear back about my job today - i better! I'll ring at the end at the end of the day if i havent heard ..... im not filled with confidence.
Just gotta fax something off to parliament
