  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My best bud has had it real bad ....ear infections .... coughing .... etc. She's ahd it for about a month now ..... i got it bad last year and managed to escape it this year .... then again couldve been all the drugs i took last year for it still roaming round in my body :P
