  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
doing the same thing as you :)
but otherwise good ....... took Granny and Grandpa out for wedding aniversary today ..... got Granny pissed then i drove home and dragged a statesmen .... gave granny a heartattack.
i miss my car ...... i was really disappointed in the power of my mums Clubby when i went to drag that Senator ... its so slow .... i won but still the reaction was ridiculous. Folks wont let me touch the ZX .... not insured and about to go to caryard so im driving a bunky laser :D
I keep it up cos i have a boring job ....... one of those jobs that im employed but god knows why cos i dont do nothing all day ..... im a govt worker thats how i keep up ..... otherwise yeah i would have a sad post count cos i dont normally post much at night or weekends.
With car: some dickhead ran a red light ...... the impact was fairly low as i managed to brake and he locked his up and sailed into me ...... so the damage was cosmetic but afterwards he reversed and just took off ...... old wog guy in a bunky car. So the panel beater has fixed the front end of my car ..... just waiting for the rear veilside wing to go on (added extra :) )
cant wait to hav emy car back - i miss it so much - its very sad actually!!
guess you could understand!! how long til yours comes back?
It goes to the exaust shop tomorrow, should be back at performanz that day. Then sst have to put the wolf in and tune it, and tony at jagmobile next door to sst has to install my fuel pump. Maybe wednesday, well should be next week anyway.
Lotsa bitz going in Hicks!! What kinda exhaust you getting ..... thinking of updating mine ..... get rid of the gay SS tip ..... probably use the money from selling GTR wing.
Should be a beast after u finished ..... did you buy a new turbo?
Hey Aidwin ...... you werent at Dyno day today?
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
