  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:shake:
Still recovering. I had a bit of a hang over sat morning.
Guess what? Troys doing the dishes!!
Oh yeah and mum got me a printer/scanner/photo coppier in one for my bday.. sneaky bugger, she had me convinced i was getting a holliday. Wicked printer but. Make uni so much easier!!
OH THANKYOU THANKYOU THANKYOU THANKYOU THANKYOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just warning you though, somthing very heavy needs to be moved. My piano. Dont worry though its not in my apartment at the moment, So we dont have to some how move it on stairs. Its at mums. Its just very very very very heavy. But a friend of mine may lend me a forklift for the weekend that i move out so we can move it.
