  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
A bus stops and two Italian men get on. They sit down and engage in an animated conversation. The lady sitting behind them ignores them at first, but her attention is galvanised when she hears one of the men say the following:
"Emma come first. Den I come. Den two asses come together. I come once-a-more. Two asses, they come together again. I come again and pee twice. Then I come one lasta time." "You foul-mouthed sex obsessed swine," retorted the lady indignantly.
"In this country....we don't speak aloud in pubic places about our sex lives.........
"Hey, coola down lady," said the man. "Who talkin' abouta sexa? I'm a justa tellin' my frienda how spella 'Mississippi'."
I BET YOU READ THIS AGAIN!!
OK, TO ALL THOSE USIN A MINIDV CAM'S USE A TRIPOD WHEN ZOOMING INTO DETAIL.....LOTS OF INTERLACING PROBLEMS AS THE CAMERA IS DIGITAL IN MECHANISM BUT THE TAPES ARE STILL PART ANALOGGGGGG......
AND USE PROGRESSIVE SCAN....
EVERY FRAMEX2 FOR QUALITY.....
JUST A FEW THINGS TO THINK ABOUT WHEN TAKING A FOOTAGE FOR A DVD IN THE FUTURE......
AGAIN EXCUSE THE CAPS I AM RENDERING......
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
