  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul i said in the post that this was the time they went out - the rare time they went out ..... and you played on the computer and im like "well obviously i aint going to be getting any" so i watched TV .... haha shouldve gone out to find attention .... its usually what i do when i get knocked back for something like a computer.
i have to wonder about you sometimes paul ..... when will they invent a shaking head smiley!
Dan the weather is lovely to nice to be in here.
haha i was wondering if they delivered to West Perth ;) ..... trust Bam to have that number!
