  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Pauls yours is not bad ..... whatever the gel is its good it doesnt make your hair feel like cardboard. :P
Actually ive got a think about stiff cement hair ..... i dont use any styline products in mine ..... i own a bottle of mousse which i never use .... ive got this serum stuff that makes my hair soft n shiny and if i use that and blowdry my hair that is usually enough to keep my hair in shape.
so much talk about hair products ..... gone from turbos to blowdryers in the space of a page :) who said whoring was dead!
haha thanks boys your making me blush :(
Lee what pictures have you got - ive only got one so far :P
Yeah paul im having a few naughty days - cos i was sooo good leading up to PAS then im back to gym - and swimming now our pool all heated and clean :)
yeah imagine there would be a lot of funny looking men with sideburns at the hotrods show ..... bloody elvis impersonators :)
sounds good paul :P weather should be high 20's on weekend.
Nah i didn't go to the Hot Rod show, even though my inner Trev told me to go :bahaha:
I saw you there paul and should have said hi when Bretts car was on the dyno, but didn't get a chance to catch up with you after that as i had a busy schedule that day so was duck in have a look and leave :)
Niz seen a few pics on various sites, :P
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
