  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Pauls yours is not bad ..... whatever the gel is its good it doesnt make your hair feel like cardboard. :P
Actually ive got a think about stiff cement hair ..... i dont use any styline products in mine ..... i own a bottle of mousse which i never use .... ive got this serum stuff that makes my hair soft n shiny and if i use that and blowdry my hair that is usually enough to keep my hair in shape.
so much talk about hair products ..... gone from turbos to blowdryers in the space of a page :) who said whoring was dead!
haha thanks boys your making me blush :(
Lee what pictures have you got - ive only got one so far :P
Yeah paul im having a few naughty days - cos i was sooo good leading up to PAS then im back to gym - and swimming now our pool all heated and clean :)
yeah imagine there would be a lot of funny looking men with sideburns at the hotrods show ..... bloody elvis impersonators :)
sounds good paul :P weather should be high 20's on weekend.
Nah i didn't go to the Hot Rod show, even though my inner Trev told me to go :bahaha:
I saw you there paul and should have said hi when Bretts car was on the dyno, but didn't get a chance to catch up with you after that as i had a busy schedule that day so was duck in have a look and leave :)
Niz seen a few pics on various sites, :P
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
