  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kutter, All Joe's are odd;)
hahah shut up pauly, you can talk...
Dan, I love chopping people in my car, I come along side them then let the screamer pipe off in there ears:D
that can be mean so many things... lol:bahaha: :) you got enought room in the back?
Aidwin.. good to hear mate.. don't go getting toooooo much hp. I'm starting to get left behind.
Paul.. thinking of getting Ray to put in a Wolf. are map sensons and boost controller a pay extra option..? any idea of the cost.?
what do you reckon for a tune down at SST.. around the 4-500 mark..?
Joe, I don't mean :fart: in there ears:p
Aidwin, I'm glad that twin turbo magna didn't beat me in the dyno comp:D
hahah so people pass out cuz of smell or the sound? LOL
Twin Turbo magna? WOOT? COOL
RalliArt Twin Turbo MAGNA All Wheel Drive. that's awesome :)
Shan, The wolf is $1395, comes with a boost controller and MAP sensor. All you need to do is run a vacuum hose from the manifold to the ECU, the boost controller can run the stock ECU. Steve generally does the install and tune for $2000 for SAU members, if you do the install yourself it may be cheaper.
Aidwin, Funny is one way to put it;)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
