  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kutter, All Joe's are odd;)
hahah shut up pauly, you can talk...
Dan, I love chopping people in my car, I come along side them then let the screamer pipe off in there ears:D
that can be mean so many things... lol:bahaha: :) you got enought room in the back?
Aidwin.. good to hear mate.. don't go getting toooooo much hp. I'm starting to get left behind.
Paul.. thinking of getting Ray to put in a Wolf. are map sensons and boost controller a pay extra option..? any idea of the cost.?
what do you reckon for a tune down at SST.. around the 4-500 mark..?
Joe, I don't mean :fart: in there ears:p
Aidwin, I'm glad that twin turbo magna didn't beat me in the dyno comp:D
hahah so people pass out cuz of smell or the sound? LOL
Twin Turbo magna? WOOT? COOL
RalliArt Twin Turbo MAGNA All Wheel Drive. that's awesome :)
Shan, The wolf is $1395, comes with a boost controller and MAP sensor. All you need to do is run a vacuum hose from the manifold to the ECU, the boost controller can run the stock ECU. Steve generally does the install and tune for $2000 for SAU members, if you do the install yourself it may be cheaper.
Aidwin, Funny is one way to put it;)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
